robyn2117's avatar
robyn2117
Follower
Jan 15, 2019
Netgear Nighthawk MR1100 drops in and out even after adding a 7dBi Gain antennae
I live 48km from Perth at Serpentine on the coast side of the Darling Ranges.. My ADSL2  connection deteriorated over the past 5 years and drifted between 0.4mbps and 1.6mbps despite numerous visits ...
  • Blanca_O's avatar
    Mar 07, 2019
    Hi robyn2117
    Please check the signal quality using the Diagnostic screen found under Settings > Nighthawk M1 Status > Diagnostics.
    RSRP : typical range is around -44dbm (good) to -140dbm(bad).
    RSRQ : typical range is -19.5dB(bad) to -3dB (good).
    You can also move the device to a location/area with clear view of the sky.
    Blanca
    Community Team
