NighthawkMR1100
Oct 31, 2022Aspirant
Netgear Nighthawk MR1100 External Antennas will actually boost signal?
I have a Netgear Nighthawk MR1100 and have tried several external antennas that state they will boost the cellular signal from a tower. They do not.
After reading several chats, it seems W1lliam stated that the antenna ports on M1, these two ports only designed for low bands (such as B1/3/8/28..,etc.).
I've also tested the speed with the MIMO antenna plugged into the MR1100 and unplugged and the speed tests are not improved by the antenna. I've also used open signal to pinpoint the direction of the AT&T tower and have the antenna facing that direction.
So in short, what external antennas would actually boost our signal?
Current Radio Band LTE B14
RSRP -99 dBm
RSRQ -9
RS-SINR 18dBm
- W1lliamVirtuoso
I did try with Netgear MIMO antenna, TS-9 connector, when dealing with B1/3/7/8/28, got some improvement. But had not investigated further if that helps high band, FYI.
- NighthawkMR1100Aspirant
Thank you!
NETGEAR 6000450 MIMO Antenna with 2 TS-9 Connectors is the last external antenna that I tried. . Got it from Amazon. I think it's the same one you tried.
The one over at ebay you mentioned is a NETGEAR 6000450 MIMO Antenna for 3G/4G Air Card USB
Is this the same antenna?
FYI My current band is LTE B66
I read on another post to possibly connect a NETGEAR Orbi mesh WiFi system to the ethernet port of the Nighthawk. I've just ordered this and will try it out.
