Danielaurence
Mar 10, 2023Follower
Netgear Nighthawk MR1100 M1 Frozen on Boot Logo with Solid Amber Light and Won't Hard Reset
Hello, I have been using an M1 mobile router with an AT&T sim card for my rural home internet, but recently, when turning on the device, it has frozen with just the "NETGEAR" boot logo and a soli...
JohnPeng
Mar 12, 2023NETGEAR Expert
Danielaurence wrote:
Hello,
I have been using an M1 mobile router with an AT&T sim card for my rural home internet, but recently, when turning on the device, it has frozen with just the "NETGEAR" boot logo and a solid amber light. This happens every time the device is booted up, and it is completely unresponsive. It will not power down, hard reset, or be detected when connected to a PC. The only way to power it down is to remove the battery. I have tried removing the sim card and holding down the reset button, but it is completely unresponsive.
IMEI: 015161000747447
SKU: 6420B
Any troubleshooting help is greatly appreciated, as I rely on this device for my work. Thank you.
If the device can't boot up without SIM, it may be broken permanently.
Thanks
