ANTONYVA
Mar 08, 2024Follower
NETGEAR Nighthawk RAX120 AX6000 Dual-Band 12-Stream can connect with MR100?
I have NETGEAR Nighthawk RAX120 AX6000 Dual-Band 12-Stream and ,I am using MR100 Wireless modem. i need 2 more LAN line ,so I can connect to NETGEAR Nighthawk RAX120 AX6000 Dual-Band 12-Stream ?
There are 4 more LAN ports available that can be used as LAN Cable by connecting thru MR100.
1 Reply
this statement was rather disjointed and confusing.
I'm not sure exactly what you're trying to do.
You have the Mr1100 with the RAX120 connected to it.
And you're needing extra lan ports?
A cheap unmanaged switch can be beneficial
