anthony12728282
Feb 10, 2018Follower
Netgear Wireless-N Dual Band Router
Why is my Ethernet LED blinking green? It’s preventing me from connecting to my wifi network on my Xbox One.
- JasonNNETGEAR Employee Retired
Hi anthony,
The blinking green LED on the ethernet port is normal. It means that it has a Gigabit Ethernet connection. Please refer to the link below for the kb guide of LED meaning. Is your router to the current firmware? If so, did you do a factory reset after the update? Have you checked the configurations on the xbox side? can other devices connect to the router?
Ethernet LEDs
The LED color indicates the speed: white or green for Gigabit Ethernet connections and amber for 100 Mbps or 10 Mbps Ethernet connections.
- Off. No device is connected to this Ethernet port.
- Solid. A powered-on device is connected to the Ethernet port.
- Blinking. The port is sending or receiving traffic.
https://kb.netgear.com/24244/Understanding-NETGEAR-LED-Symbols
- Jason N
HI anthony,
I just wanted to check in and see if this worked for you?
Please let me know :]
- Jason N
