Trebor7
Jan 07, 2020Aspirant
Netgear4GX Advanced iii and Netgear aircard smart cradle DC 112A?
First post. Not my forte! Both units supplied by Telstra and has worked well. About a month ago, the data usage displayed on the 4GX modem changed to data not available at this time. Noted many s...
JohnPeng
Jan 08, 2020NETGEAR Expert
The data usage issue was due to the recent update on Telstra server side. We are going to release new FW to fix this this month.
For the WiFi connection issue with Samsung Galaxy Tab A, please provide the detailed information on the Galaxy Tab A. We can check what may cause the incompatibility with DC112A.
Thanks
- Trebor7Jan 15, 2020Aspirant
Hi. An email asked if a solution had been found. Yes , thanks to John. The second part about Samsung Galaxy tablet - hopefully all the info John requested was received in my reply. Should it not have bee received, please let me know and I will send again.
Can I ask if the FW update for the DC112A is automatic, or what do I have to do. Thank you.
- Trebor7Jan 26, 2020Aspirant
Hi John Peng.
Did you receive my Samsung tablet details? Any progrees as still cannot use.
Went to http:// 192.168.100.1 Advanced Admin, Router Upgrade and downloaded the one shown - seemed to be more about language than Telstra problem, so still not getting usage data. Many thanks.
- JohnPengJan 26, 2020NETGEAR Expert
The fix for Netgear4GX Advanced iii data usage issue is being tested in Telstra and hope we can get appoval soon. Expect to release the update online in the next two weeks.
I don't think I received the tech detail on your Samsung tab. Could you please send a private message to me?
Thanks
