Colesy's avatar
Colesy
Follower
Mar 01, 2017
Nighhawk M1 data offloading
I now have two internet connections at home. My ADSL which runs at 4 GBPS and drops out and my nighthawk which is over 20 GBPS, however the nighthawk has very very limited data. I noticed the data offloading on the app I dowloaded. My question is, can I download some of my used data to my ADSL and basically pay the normal ADSL rate for it by continually offloading my used data? my usage is around 500 G per month and the nighthawk max is 80 G.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Colesy
    You may have to check with your ISP about that.
    DarrenM
