gyorsto
Oct 27, 2017Aspirant
Nighthawk AC 1900 and 4G Modem LB2120
I just bought a 4G Modem LB2120 to supplement a failing ADSL service. The Modem works brilliantly on it's own however I would like to feed it into my Nighthawk AC1900 D7000. Everything I have read sa...
JamesGL
Nov 02, 2017NETGEAR Employee Retired
Hi gyorsto,
Please try the steps shown on the installation guide.
http://www.downloads.netgear.com/files/GDC/LB2120/LB2120_QSG_EN.pdf
Let me know if it doesn't work.
gyorsto
Nov 06, 2017Aspirant
Hi James,
Thanks for the link. I receieved that quick start booklet with my modem and have followed that. For extra detail I downloaded the detailed user manual that talked about switching router mode to feed directly into my D7000 router. I have followed all of the instructions without any success.
I would be greatful for more detail on the requred settings in both devices.
- JamesGLNov 09, 2017NETGEAR Employee Retired
Hi gyorsto,
May I know what is the firmware version of the LB2120?
- gyorstoNov 09, 2017Aspirant
Hi JamesGL,
The firmware of the LB1210 is up to date - I have performed the search for new software a few times now.
Firmware is M18QW_v07.05170721. The device is the Ausralian version if that matters.
My Nighthawk D7000 is on firmware V1.0.1.50_1.0.1
- gyorstoDec 07, 2017Aspirant
Hi JamesGL,
Just wondering if I can expect a response or should I just go to customer support?
