Image1981's avatar
Follower
Oct 12, 2016
Nighthawk AC1900 WiFi LTE Modem Router
Hello,
I have purchased the Nighthawk AC1900 WiFi LTE Modem Router model R7100LG because I don't have a internet connection nearby, this model has the option to use a simcard so I have a "hotspot" wifi connection. This is working like it should and no problems what so ever.
Now here's the challenge.... I also want to use this mobile data to create internet over ethernet, there are 4 ethernet ports on the router but I can't seem to "share" this mobile data over the ethernet ports, does anybody know if this is even possible and in case it is possible, which settings should I apply to get it to work?
Thanks
    • NeilS's avatar
      NeilS
      NETGEAR Expert
      Hi...
      Assume your LTE connection is up and running, so the R7100LG Broadband settings are configured accordingly, ie., "Always use Mobile Broadband Connection".
      Once done, multiple clients connected to the R7100LG via wired ethernet or wireless, will be able to successfully access the Internet.
      There should be no other configuration necessary to achieve this.
