veganbels
Jun 19, 2022Follower
Nighthawk and a LTE booster questions.
Hello, I just received a LTE booster (surecall EZ 4GV signal booster) from Verizon to help with my LTE signal. It seems like its working much better on my phone. I have done a speed test, and my speeds almost dobuled to about 35mbps. But I have a Netgear Nighthawk M1 that I use for my PC. This doesnt seem to show the same speeds as my cell phone. Is there any reason for this? Or are there some settings i need to change in the Netgear M1 device? Any tips or help would be appreciated.
1 Reply
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
