AnunC8
Apr 22, 2019Aspirant
Nighthawk and roof antenna
Hey folks. I really hope someone can help, because I am at my wit's end here. I purchased this Nighthawk because the area we just moved to doesn't have any broadband providers. Sadly, the connection I...
AnunC8
Image attached
Apr 22, 2019Guru - Experienced User
My understanding is the MR1000 uses a TS-9 jack. I know the Yagi has N-female. It looks like your cable has n-male adapters on both ends. I'm not 100% because (i'm not there) I don't know what cable you ordered and i'm not even sure if it'll work but they make a ts9 to N-female adapter. Amazon lists them. Just do a search and make sure the listing is exactly what you want. I've never tried to do something like this so this is just a best guess of what you've provided.
https://www.amazon.com/Coaxial-Bulkhead-Connector-Adapter-Extension/dp/B01M9CF8K0
If your cable has different ends or male/female ends, you'd need to change your search parameters.
