JASON1962
May 08, 2023Follower
NIGHTHAWK AX3600-5
I am trying to configure the following system.
Netgear M100 hotspot---->netgear GS105 switch-------> Netgear AX3600-5 ------> Netgear MR60---->NetgearMR63
CAt 6 cable connecting everything but I Can't get the MR60 to connect to the data from the Switcher.
Is there another path that the connections need to be routed? I have tried the MR60 input from the switcher as well as the AX3600-5 wifi router/modem.
Would help to know the product number of AX3600-5 (perhaps from the product label attached to the device).
When I enter AX3600-5 into the Netgear support site, nothing shows up:
https://www.netgear.com/support/
The mobile routers work great but they can get bogged down with to many devices.
What I'd do is go M5 in passthrough mode to a router (in router mode), then to your switch and then to the MK63 system (with the MK system in access point mode).
