nhantenna
Apr 12, 2018Apprentice
Nighthawk LTE hotspot + automatic firmware nightmare
I live in the United States. I have an AT&T issued Nighthawk LTE hotspot running on AT&T network. For the last several weeks I have been reading this forum about automatic firmware updates occurrin...
nhantenna
Jun 14, 2018Apprentice
@JasonN Blanca_O I am following up on this thread. This thread is 63 days old without any technical response from Netgear. Please escalate.
- Blanca_OJun 18, 2018NETGEAR Employee Retired
Hi All,
Please be informed that NETGEAR and AT&T are working on a firmware. We will provide update once new information will be available.
Blanca
Community Team
- Blanca_OJun 21, 2018NETGEAR Employee Retired
Hi All,
We just had a new firmware certified by AT&T that should fix the issue. Please log into the MR1100 UI and check for an update to get the latest firmware.
The FW should NTG9x50C_12.02.06.01 and PRI should be 2.15
Please provide us feedback once you have the lastest firmware installed.
Blanca
Community Team- shizam76Jun 22, 2018AspirantTo be exact, what is the firmware fixing? It will no longer do updates on its own?
- Blanca_OJun 24, 2018NETGEAR Employee Retired
Hi shizam76,
May I please know the behavior of the device when you try to update the firmware?
Blanca
Community Team - nhantennaJun 26, 2018Apprentice
Blanca_O The new firmware did NOT fix the issue. The new firmware causes the EXACT problems stated in the original post. It has now been 76 days since this issue was reported without any technical response from Netgear. Pushing yet another automatic firmware that trashes our Nighthawks without warning is NOT a technical response.
- nhantennaJul 05, 2018Apprentice
Firmware levels on my Nighthawk:
Hardware Version = 1.0
PRI Version = 02.15
Firmware Version = NTG9X50C_12.02.06.01
Bootloader Version = NTG9X50C_12.02.06.01
GUI Version = MR1HDATA_04.01.55.02
Firmware Build Date = 2018/06/07
- Blanca_OJul 05, 2018NETGEAR Employee Retired
Hi nhantenna,
Thank you for providing the requested information. Let me check this with the team.
Blanca
Community Team
