nhantenna
Apr 12, 2018Apprentice
Nighthawk LTE hotspot + automatic firmware nightmare
I live in the United States. I have an AT&T issued Nighthawk LTE hotspot running on AT&T network. For the last several weeks I have been reading this forum about automatic firmware updates occurrin...
nhantenna
Jun 14, 2018Apprentice
@JasonN Blanca_O I am following up on this thread. This thread is 63 days old without any technical response from Netgear. Please escalate.
Blanca_O
Jun 21, 2018NETGEAR Employee Retired
Hi All,
We just had a new firmware certified by AT&T that should fix the issue. Please log into the MR1100 UI and check for an update to get the latest firmware.
The FW should NTG9x50C_12.02.06.01 and PRI should be 2.15
Please provide us feedback once you have the lastest firmware installed.
Blanca
Community Team
- shizam76Jun 22, 2018AspirantTo be exact, what is the firmware fixing? It will no longer do updates on its own?
- Blanca_OJun 24, 2018NETGEAR Employee Retired
Hi shizam76,
May I please know the behavior of the device when you try to update the firmware?
Blanca
Community Team- Blanca_OJun 26, 2018NETGEAR Employee Retired
Hi shizam76,
Kind;y update the firmware with the battery out of the unit.
Blanca
Community Team
- nhantennaJun 26, 2018Apprentice
Blanca_O The new firmware did NOT fix the issue. The new firmware causes the EXACT problems stated in the original post. It has now been 76 days since this issue was reported without any technical response from Netgear. Pushing yet another automatic firmware that trashes our Nighthawks without warning is NOT a technical response.
Blanca_O states: "Please log into the MR1100 UI and check for an update to get the latest firmware."
Just for clarity....the firmware is automatically installed without warning and without user intervention. The firmware fails to install and the nighthawk is taken offline. There is no way for Nighthawk owners to opt out of this automatic firmware install.
