traceybaysinger
Mar 25, 2020Aspirant
Nighthawk LTE
Can someone please verify if there is a difference? Im looking for a Netgear Nighthawk LTE. When I search I see the M1100 series.
Is this the same or are they different?
Thank You for any help
Tracey
- JohnPengNETGEAR Expert
Please advise how you plan to use the device?
Thanks
- traceybaysingerAspirantWe are in a rural area. But cell phones work good. So we are going to use as an internet option to our home
For this case, You have two options:
1. Get MR1100 Retail version on Amazon. Then you can get a mobile hotspot data plan from any carriers that support M1 and have better coverage at your area.
2. Get the AT&T version MR1100 with their data plan. You need to make sure ypu have better AT&T coverage at your home.
Thanks
