MAJOR-z-BOMBASU
Mar 07, 2019Guide
Nighthawk m1 - 5510 port state: filtered
I'm owner of MR110-100EUS that works with software: NTG9X50C_12.04.02.00 It does not matter if I connect with WI-FI, or with USB tethering, the port 5510 is always filtered so i can't access to cons...
- Mar 07, 2019
Ok, i found that it does not matter if port is filtered or not.
It is enough to connect with USB, then just use telnet 192.168.1.1 5510you will see just black screen without any kind of information, like i show below:
It is confusing, no message that you connected etc. ;)
So, once you will see this weirdy-looking black screen without any responsse - it is just enough to start type the AT commands.
MAJOR-z-BOMBASU
Mar 07, 2019Guide
