AnJellyCue
Apr 08, 2017Aspirant
Nighthawk M1 - Data Offset
Hello All,
I brought a Nighthawk yesteday from Telstra and I am having a particular problem with it.
I am wanting to use the Data Offset functionality,
I can set it up, it connects and 50% of the time will stay connected, the other 50% is it doesn't connected to the WiFi network, both the broadband and Wifi connection drops out. Once I have added in a entry - i can't disable or turn it off, the device no longer allows me to connect to it and I have to do a factory reset..
As a device, it's sublime. and connects to the Telstra network and I can connect to it via USB / Wifi and there isn't a problem (OK, sometimes the device screen says it's detecting the dashboard says it's connected to the network)
I apologise if I am vague on the above and happy to provide any additonal information you may need
- ArodiDNETGEAR Expert
Hi AnJellyCue,
I just had a couple of questions in regards to the issues you are experiencing with Data Offloading feature.
1. When you say "the other 50% is it doesn't connected to the WiFi network, both the broadband and Wifi connection drops out.", was your phone/computer not able to connect to the M1's AP or do you mean that you are offloading to a WiFi router and the M1 has dropped the WiFi connection to that router?
2. "Once I have added in a entry - i can't disable or turn it off, the device no longer allows me to connect to it and I have to do a factory reset..", - Is the router you are trying to offload to using the same IP range as the M1? (192.168.1.1), If you tried entering http://m.home/ into your web browser do you have the same issue?
Keen to get your feedback on this issue. If you could also PM me your email address so that I can contact you directly on this issue it would be appreciated.
Kind Regards,
ArodiD
- AnJellyCueAspirant
To answer your questions
1) My iphone / PC is unable to connect to the M1
2) The IP address of my router is in the 10.X.X.X range, and I have used m.home and I have the same problem, I have even tried the netgear App.
I was able to get it connected to the home WiFI perfectly. the M1 on the device showed the home WiFi. But when I went to turn off the Data Offset thats when the dashboard displayed broadband not connected / and the data offset connection unavailable.
Hi AnJellyCue,
I am little confused with your responses. For point 1 you mention that your iPhone or PC cannot connect to the M1. However, you then mention:
"I was able to get it connected to the home WiFI perfectly. the M1 on the device showed the home WiFi. But when I went to turn off the Data Offset thats when the dashboard displayed broadband not connected / and the data offset connection unavailable."
How were you able to determine the data if you were unable to connect to the M1 or are you experiencing 2 different issues?
Issue 1 - Intermittently unable to access the M1
Issue 2 - Data Offloading intermittently drops out
Please let me know if my understanding of this issue is accurate.
Kind Regards,
ArodiD
