Walkercycling
Oct 02, 2018Aspirant
Nighthawk M1 - Telstra connection issues - Cutting in and out
Nighthawk M1 Hardware version 1.0
PRI Version 03.22
Firmware Version NTG9X50C_10.25.01.01
I have started to notice a drop in the performance of my Nighthawk. I first noticed it when i woul...
W1lliam
Oct 03, 2018Virtuoso
Maybe you can try to make M1 as 4G modem only and having another wireless router , I am using Nighthawk R7800, connected to its Ethernet port. Enabling IP Passthrough on M1, so your main routing happened on the router instead of M1 and having better wireless coverage out from the router.
- WalkercyclingOct 04, 2018Aspirant
That could be a way around it. Thankyou
I have since noticed a couple of other issues which i will post below which may mean the modem is faulty and connecting a router to it may not be the best solution.
