mallinss
Apr 05, 2017Aspirant
Nighthawk M1- Ethernet Port
Hello All, I have a Nighthawk M1 devce and its working just fine, however I have a question regarding the use of the ethernet port... I have been unable to get this to behave in a manner that I w...
tomfoolery
Apr 06, 2017Aspirant
I'm not sure of all the details but there is something restrictive about the way the ethernet is set up at Telstras end. Ive been trying to get a simlar set up to yours running and it just won't work. I asked Netgear and they said to ask Telstra as the modem is set up to their standards. I've found that talking anyone at Telstra who has any real clue as to what or why it doesn't want to play ball via ethernet is, so far, impossible. Ethernet wont function with a splitter port or any consloes even when directly connected. I've found I can only connect to the internet via ethernet directly to a PC (Mac) and even then it seemed to take a few goes to connect....
mallinss
Thanks for your response.... I totally agree with you, Telstra support have no clue and shame on Netgear for restriciting proper use of this port to satisfy some stupid Telstra requirement.... from my testing, I don't see any value in the ethernet port and therefore a completely useless device... IP passthorugh does not work either, even though it is listed a feature.... I hope there is a firmware upgrade coming, until then, its staying in its box.
Steve
- SolvedFeb 27, 2018AspirantCan fix. ... just need to know how many people are interested ( use it for home or business as internet ) connected to router etc
