mallinss
Apr 05, 2017Aspirant
Nighthawk M1- Ethernet Port
Hello All, I have a Nighthawk M1 devce and its working just fine, however I have a question regarding the use of the ethernet port... I have been unable to get this to behave in a manner that I w...
mallinss
Apr 18, 2017Aspirant
This is not likely to be an issue due to MDI-X support, cossover cables are now mostly non existant due to this.. note that only one connected device needs to support this and in my case the switch I use does... I don't know whether the Nighthawk supports MDI-X, but I would be surprised if it did not.
dcouchm
Apr 21, 2017Aspirant
Hi, Well MDI-X is available in the switches I configure at work such as Cisco, however I am not so sure that it is available in SOHO devices such as the nighthawk M1. Yes, just one device supporting MDI-X should be all that is required. So I assume your switch works ok when plugged into the Nighthawk M1? What brand/model of switch are you using if you don't mind me asking?
