mallinss
Apr 05, 2017Aspirant
Nighthawk M1- Ethernet Port
Hello All, I have a Nighthawk M1 devce and its working just fine, however I have a question regarding the use of the ethernet port... I have been unable to get this to behave in a manner that I w...
Wazzal
Apr 11, 2017Tutor
I have a Telstra M1 connected to a Netgear R7000 via Ethernet without any issues. The M1 is replacing an ADSL modem on my existing network. The M1 has default settings other than wifi ssid/passwords. All network distribution is handled by R7000.
Now to get the Data Offloading to work with Telstra AIR???
Expobar
Apr 26, 2017Aspirant
Hi Wazzal
Please read my post to Steve today ( post 19 ). Can't get my M1 ethernet port to work with my 16 port unmanaged switch.
Have also read the way you have solved it and will try. Have you connected your R7000 to a switch as well.
I need to create a network comprising of 16 data points.
Have just bought a 16 port unmanaged switch, but as am sure you will understand from my other post, my NightHawk M1 is not connecting to the switch so am not able to network.
So if I connect to M1 to R7000, will I then be able to connect R7000 to the unmanaged switch.
Can I do this without needing to change any settings with the R7000 - or do I need to do a few things with it, and if so, what?
New to this, so need all the help I can get.
Thanks
Philip
