mallinss
Apr 05, 2017Aspirant
Nighthawk M1- Ethernet Port
Hello All, I have a Nighthawk M1 devce and its working just fine, however I have a question regarding the use of the ethernet port... I have been unable to get this to behave in a manner that I w...
ArodiD
Apr 27, 2017NETGEAR Expert
Hi All,
By default​ the Ethernet port is switched OFF on boot up. Plug the M1 into your switch then tap the power button once and the Ethernet port will wake up after about 4 seconds. I have tested with a POE switch for my Polycom POE phonr which works fine. Please note that once the Ethernet port has woken up, if you either unplug Ethernet cable from M1 or reboot the M1 you will be required to wake up the Ethernet port again with tap of power button. Please give this a try with your switch and let me know if you are still having issues.
Kind Regards,
ArodiD
Kind Regards,
ArodiD
- O4ramoOct 26, 2017AspirantHi. I have 2 nighthawks and one works as described with Ethernet port wake up. The new one wakes for about 10decs and then nothing.
I am intending to use them both in a Meraki Mx 65
Is the 2nd m1 an RMA ?
Help
Tim- O4ramoNov 12, 2017Aspirant
- tobysFeb 10, 2018Aspirant
UK not AU model.
Mine will NOT bring up the ethernet port if the MR1100 also has the USB type-C connected for tethering at the same time.
Disconnect the Type-C from the PC and the ethernet comes up.
- bcbuchFeb 20, 2018Aspirant
tobys you were close to hitting the nail on the head.
I have a mr1100 acting as a modem. It is plugged into the Wan port on a R7300 DST router. Here is how I figured it out. I could set it up and have it working not using passthrough until I put everything in place and plugged the mr1100 back into the power adaptor at which point the data connection was lost to the r7300. I tried it with a Cisco/Linksys router and had the same issue. The fix was simply this, go into the mr1100 settings and change the usb C port setting from Charge/Teathering to Charge. Now the my intire home network is using the one mr1100 and r7300 for internet access. I have the DST for the r7300 in the office section of the house with 2 - 4 computers hooked up to it along with 2 printers. I have a wn3000 extending the network at the other end of the house running an android Mi Box, blue ray player and tv. The r7300 is in the living room in the entertainment system with the mr1100 providing internet access to all previous mentioned plus a 60 inch 4k tv, nvidia shield, blue ray player along with whatever tablets, phones, ect are being used.
This leaves my second mr1100 for use with my Cisco lab consisting of 14 routers and switches, 4 wireless access points and controller, one desktop, 3 laptops, and whatever else I happen to be using at the time. Not an optimal solution but under the circumstances along with my location it is a working solution.
- zulu63Apr 13, 2018Aspirant
Thanks for your feed back do you know if that works in Australia with the Telstra settings?
I just wached someone on youtube validating your statement "must manualy disconnect and reconnect lan cable to obtain ethernet out"
thanks again
- WakeSSJul 25, 2018Aspirant
ArodiD's reply is the crux for me...
Seems my mr1100 AT&T version likes to randomly restart/disconnect and when it does the Ethernet port goes to sleep. I have to go connect to the MR wi-fi, push the button on the device, go to offloading, select ethernet (link light comes on) then turn offloading off to get it to connect back to my USG ubiquiti router. Same behavior connected directly to switch.
Why in the world does it not wake up the Ethernet port on reboot??
It also seems even on the new firmware NTG9X50C_12.02.06.00 that "fixed" passthrough is only valid for USB connected devices, not ethernet connected.
Sure seems they just don't want you to use that Eth port...
Anyone have any way around this?
- wkreplyAug 05, 2018Aspirant
This has been exactly my experience with the M1 connected to a USG. Ethernet port is not detected on reboot. Have to toggle data offloading over ethernet setting to get it to detect, and even when the connection lights up it's not always successful in connecting. Going to try a few other setting changes, but please post if you find a workaround or solution for this.
- WakeSSAug 07, 2018Aspirant
Still no luck for me. I thought my disconnects were prehaps due to poor signal. Now I'm running a cell booser and have -60 to -80db connections to 3+ towers. I have noticed exactly at 1AM it is resettings some nights.
At this point I'm going to look for a differnet device that has:
-Ethernet port that stays active/is active on reboot, loss of signal
-Band Locking
-Ethernet pass through
4x4 MIMO is great but I'm only getting 20Mb down 10Mb up on a good day anyway.
Anyone running anything with these features on AT&T?
