mallinss
Apr 05, 2017Aspirant
Nighthawk M1- Ethernet Port
Hello All, I have a Nighthawk M1 devce and its working just fine, however I have a question regarding the use of the ethernet port... I have been unable to get this to behave in a manner that I w...
Wazzal
Apr 27, 2017Tutor
Hi Philip
I only have the router connected to the M1. My M1is working only as a modem. I don't need the additional Ethernet so haven't tried a switch but it shouldn't be a problem. I can't remember the default configuration of the r7000 but the instructions with any router/switch should guide you through the combination setup. Try and keep the configuration as simple as possible until it is working and stable.
- ExpobarApr 27, 2017Aspirant
Hi Wazzal and ArodiD
Thanks so much for your assistance.
I have tried everything. I think there is a problem with the ethernet port - I'll take the M1 back to Telstra to fix or get a new one.
regards
Philip
- Philby12Jul 26, 2017Aspirant
Hi again, I didn't take it back, I did some more research, I forgot about function of the WAN Port on routers. As has been mentioned in this thread.
I reed some sugegsitons here what Router to use.
Would using a spare Netgear Cable Gateway Modem Router model C6300BD WAN port work or?
Thanks
Phil
