mallinss
Apr 05, 2017Aspirant
Nighthawk M1- Ethernet Port
Hello All, I have a Nighthawk M1 devce and its working just fine, however I have a question regarding the use of the ethernet port... I have been unable to get this to behave in a manner that I w...
ArodiD
Apr 27, 2017NETGEAR Expert
Hi All,
By default the Ethernet port is switched OFF on boot up. Plug the M1 into your switch then tap the power button once and the Ethernet port will wake up after about 4 seconds. I have tested with a POE switch for my Polycom POE phonr which works fine. Please note that once the Ethernet port has woken up, if you either unplug Ethernet cable from M1 or reboot the M1 you will be required to wake up the Ethernet port again with tap of power button. Please give this a try with your switch and let me know if you are still having issues.
Kind Regards,
ArodiD
Kind Regards,
ArodiD
O4ramo
Oct 26, 2017Aspirant
Hi. I have 2 nighthawks and one works as described with Ethernet port wake up. The new one wakes for about 10decs and then nothing.
I am intending to use them both in a Meraki Mx 65
Is the 2nd m1 an RMA ?
Help
Tim
Help
Tim
