mallinss
Apr 05, 2017Aspirant
Nighthawk M1- Ethernet Port
Hello All, I have a Nighthawk M1 devce and its working just fine, however I have a question regarding the use of the ethernet port... I have been unable to get this to behave in a manner that I w...
tobys
Feb 10, 2018Aspirant
UK not AU model.
Mine will NOT bring up the ethernet port if the MR1100 also has the USB type-C connected for tethering at the same time.
Disconnect the Type-C from the PC and the ethernet comes up.
bcbuch
Feb 20, 2018Aspirant
tobys you were close to hitting the nail on the head.
I have a mr1100 acting as a modem. It is plugged into the Wan port on a R7300 DST router. Here is how I figured it out. I could set it up and have it working not using passthrough until I put everything in place and plugged the mr1100 back into the power adaptor at which point the data connection was lost to the r7300. I tried it with a Cisco/Linksys router and had the same issue. The fix was simply this, go into the mr1100 settings and change the usb C port setting from Charge/Teathering to Charge. Now the my intire home network is using the one mr1100 and r7300 for internet access. I have the DST for the r7300 in the office section of the house with 2 - 4 computers hooked up to it along with 2 printers. I have a wn3000 extending the network at the other end of the house running an android Mi Box, blue ray player and tv. The r7300 is in the living room in the entertainment system with the mr1100 providing internet access to all previous mentioned plus a 60 inch 4k tv, nvidia shield, blue ray player along with whatever tablets, phones, ect are being used.
This leaves my second mr1100 for use with my Cisco lab consisting of 14 routers and switches, 4 wireless access points and controller, one desktop, 3 laptops, and whatever else I happen to be using at the time. Not an optimal solution but under the circumstances along with my location it is a working solution.
