mallinss
Apr 05, 2017Aspirant
Nighthawk M1- Ethernet Port
Hello All, I have a Nighthawk M1 devce and its working just fine, however I have a question regarding the use of the ethernet port... I have been unable to get this to behave in a manner that I w...
Wazzal
Apr 12, 2017Tutor
Steve
I suspect that the Nighthawk M1 Ethernet port does not access the Router functions available via wifi access to the M1? If you are using a switch, it's not designed to connect LAN to Internet/WAN. Still no Router function.
If you have an old Router or Modem/Router laying around try setting up your LAN on that device or connecting it in line between your PoE Switch and the Nighthawk M1.
Feb 27, 2018Aspirant
