mallinss
Apr 05, 2017Aspirant
Nighthawk M1- Ethernet Port
Hello All, I have a Nighthawk M1 devce and its working just fine, however I have a question regarding the use of the ethernet port... I have been unable to get this to behave in a manner that I w...
ArodiD
Apr 27, 2017NETGEAR Expert
Hi All,
By default the Ethernet port is switched OFF on boot up. Plug the M1 into your switch then tap the power button once and the Ethernet port will wake up after about 4 seconds. I have tested with a POE switch for my Polycom POE phonr which works fine. Please note that once the Ethernet port has woken up, if you either unplug Ethernet cable from M1 or reboot the M1 you will be required to wake up the Ethernet port again with tap of power button. Please give this a try with your switch and let me know if you are still having issues.
Kind Regards,
ArodiD
Kind Regards,
ArodiD
zulu63
Apr 13, 2018Aspirant
Thanks for your feed back do you know if that works in Australia with the Telstra settings?
I just wached someone on youtube validating your statement "must manualy disconnect and reconnect lan cable to obtain ethernet out"
thanks again
