Lenoom
Feb 26, 2019Tutor
Nighthawk M1 4g blocked by career
Now and today The company STC has blocked 4G with nighthawk m1 All type of network band of 4g, alot of people have this device they can use only 3G band Which is very slow , behave of other ow...
Blanca_O
Feb 27, 2019NETGEAR Employee Retired
Hi All,
We will check on this. We will get back to you guys for any updates.
Blanca
Community Team
khalid45454545
Feb 27, 2019Initiate
Blanca_O wrote:
Hi All,
Blanca
Community Team
you must know that:
we have same problem in Huawei product
huawei give us method change imei from talnet and all band back work
so i think you must give us method how can change imei in your product( i think that is the solution only no other solution)
specially m1
no problem if must open and do some edit inside it we ready
just we want it back work fine
if you not give us method that will big problem we will not come back to buy any new device from netger so method change imei must soon Availability
- LenoomFeb 28, 2019Tutorخل عندك اسلوب بالرد
مو واقفين عليك هم
لو ماشتريت شي
