Greynomand's avatar
Oct 11, 2017
Nighthawk M1 and Arlo Support
When will the support be ready for Arlo for the Telstra Nighthawk M1
  • Hi Greynomand,
    Should be available mid Q1 2018.  Look out for a firmware update around that time.
    ArodiD
  • but that will be a 4G connection,  In Austalia ISP's for 4G internet use a private Ip address,  so how are you supposed to access the cameras remotely?
    I've tried using an E5573 -> MR3420 -> Netgear base station, and was unable to connect to the base station...
    If there is a work around i would be very interested.
    • ArodiD's avatar
      ArodiD
      NETGEAR Expert
      Hi Addyhash,
      It uses cameras use cloud servers so does not require public IP or manual port forward configurations.  For more info please check out this link: https://www.arlo.com/au/default.aspx
      ArodiD
  • ArodiD's avatar
    ArodiD
    NETGEAR Expert
    Hi Greynomand,
    ArodiD
