BrettWW
Jun 22, 2017Aspirant
Nighthawk M1 and WD Mycloud mirror
0Does anyone know if it is possible to connect a WD Mycloud mirror to the Ethernet port on the Nighthawk m1 so I can use it as a media server?
BrettWW
Jun 23, 2017Aspirant
Thanks for the suggestion. I will give it a go. If I can get it to work it will allow me to eliminate a Telstra gateway pro/net gear v7610 which I've not been happy with.
