dark_storm83's avatar
dark_storm83
Nighthawk m1 (att version) stuck in bootloop
My nighthawk m1 is stuck in a bootloop. The netgear icon comes on and the orange light comes on then it goes out and the screen goes black for a second and starts over again. It does this 5 or 6 times then turns off and you have to remove the battery to get it to come back on.
I have tried it plugged in and not plugged, I tried starting with the battery removed and still get the same thing. The reset button does not seem to affect it at all.
  • How about booting without sim card ? If it starts up normally, then factory reset.
  • Sorry I forgot to add that, I have tried both with and without the SIM card and still no change.
    • TeeJay74's avatar
      TeeJay74
      Virtuoso
      I think it is time to go for warranty replacement.
