BobAu
Dec 01, 2018Tutor
[Nighthawk M1] B40 2300MHz and B7 2600MHz signal cannot be improved by external antenna
I am reporting a pretty sad testing result about M1 with external antenna. The signal strength and quality of B40 2300MHz and B7 2600MHz cannot be improved by external antenna!!! Definitely!!!
BobAu
Dec 01, 2018Tutor
New test is coming. Let's say two antenna connectors are A and B, and two external antenna ports in M1 are a and b.
I tried, A-a only, A-b only, B-a only, B-b only, A-a/B-b and A-b/B-a, all same results.
But found an interesting result, at the first 30 seconds when plugging one external antenna into the left external antenna port, the 2300 MHz and 2600 MHz signal strength did increased from -125 dBm to around -90 dBm, but it shows 3G parameters, the firmware or system seems treating those 2300 MHz and 2600 MHz signal as 3G signal. It's kind of strange.
Please have a look at the screenshot: https://photos.app.goo.gl/4iCCvw33FwEAKbJr6
BobAu
Dec 02, 2018Tutor
I cannot edit my post. Regarding "M1(Hong Kong version, SKU: MR1100-1EEEUS)", MR1100-1EEEUS supports B1/3/7/8/20/28/38/40/41 while MR1100-1TLAUS only supports B1/3/7/8/28. I bought MR1100-1EEEUS from Hong Kong, but finnally I think it's an unlocked M1 from EE UK.
