The_Mule1987
Aug 14, 2018Tutor
Nighthawk M1 battery charging problem
Hi there , I recently bought the unlocked version of the m1 nighthawk router and it was great 3 days ago . Suddenly , a charging issue started to occur with no reason , when my battery died I plugged ...
TeeJay74
Aug 14, 2018Virtuoso
I have seen this happening with several MR1100-100EUS devices. I have reported this to Netgear and some investigation is going on, no results yet.
TeeJay74
I managed to get full 100% charge after complete discharge/recharge cycle which took some time.
- The_Mule1987Aug 14, 2018TutorDid you experience a non full charge before , if yes then what exactly did you do to fix the problem . I never charged my router before battery completely shutdown. I always charge when the battery is dead and still I don’t get a full charge
- TeeJay74Aug 14, 2018Virtuoso
Yes, I have experienced this before, but now issue came back again, battery charge again 97%.
- TeeJay74Aug 16, 2018Virtuoso
It is possible to display 86 lines of information about M1's battery and charging which clearly indicates that Netgear takes product safety considering battery very seriously.
