Speegs
Mar 13, 2017Star
Nighthawk M1 battery flat and offline in morning
Hello, I have a Telstra Nighthawk M1, works pretty well. Happy with the speeds, the form factor, real ethernet port and on the very infrequent times I use it without power the battery life. ...
Gbear1984
Feb 18, 2018Tutor
Hi ArodiD
Is it possible for me to join the Beta team too?
Deb-M
Feb 25, 2018Initiate
Totally agree the thermister is way off. It is showing my ambient temperature at 32c (89.6f).
Room is at 23.88c (75f). Same for the batter temperature. Showing about the same. Battery is cool to touch.
- AlbertMartinFeb 25, 2018GuideHi, maybe the thermister is ok. It measure the device temp and not the ambient temp. Another temrmister is used to meassure the battery temp. But the promblem seems to be more of the program set point temperature. It seems that at near 37 C the charging is disable by the device program. Netgear has to increase the set point more.
