Speegs
Mar 13, 2017Star
Nighthawk M1 battery flat and offline in morning
Hello, I have a Telstra Nighthawk M1, works pretty well. Happy with the speeds, the form factor, real ethernet port and on the very infrequent times I use it without power the battery life. ...
ronaldnaka
May 03, 2018Aspirant
Removing the batter and putting it back fixed the problem...
Thanks
AlbertMartin
May 03, 2018Guide
Hi,
As soon as the battery gets hot again, it will stop charging.
