Speegs
Mar 13, 2017Star
Nighthawk M1 battery flat and offline in morning
Hello, I have a Telstra Nighthawk M1, works pretty well. Happy with the speeds, the form factor, real ethernet port and on the very infrequent times I use it without power the battery life. ...
Ayed
Dec 18, 2018Initiate
If you believe the power adapter is not capable of charging the device, then try switching off one of the two WIFI modes on the router. This way the power consumption will drop and the power adapter will be enough.
I hope this helps.
I hope this helps.
- JSchnee21Dec 18, 2018Virtuoso
Hi Ayed,
The issue is that the battery thermal management in the MR1100 is too conservative. It stops charging due to "overheating" because the "hot" temp threshold is set too low. This is a known issue with this product. This product unfortunately was not designed for hot climates (I wonder if the AUS or EUS versions are any better)This is a simple software change in firmware that Netgear seams unwilling to change. General consensus is that Lithium ion batteries are safe to charge up to at least 45C, some would even say 60C. But the MR1100 stops charging due to thermal sensitivity at like 35-37C.
Charging slower should help some. Leaving the case open and/or setting up a small fan also helps.
Occassionally there are also bad batteries that heat too much while charging.
- AllianceITDec 18, 2018Tutor
AUS version isn't any better. We had a few Nighthawk batterys bulge as well leading to the batteries being removed.
We have started to replace all our always on Nighthawk devices with mains power devices now that additional devices are available from our carrier.
- SpeegsDec 18, 2018Star
What mains power devices are you using? I'm interested in Nighthawk M1 performance from something without a battery. That is happy to run as a "Router" 24/7/365. M1's are great, if only Netgear just made an always on edition. Instead of just saying we designed these for hotspot short term use only.
