firstnetgirl
Apr 04, 2018Aspirant
Nighthawk M1 can operate without battery when plugged into the charger?
Does anyone know if this hotspot can operate without the battery when plugged into the charger?
- JasonNNETGEAR Employee Retired
Hi firstnetgirl,
Can you confirm that you are talking about the Nighthawk M1 (MR1100)?
Please refer to the link below for the information that you need.
You are able to run the M1 without the battery.
Make sure that your AC unit has enough power to power the device.
Please let me know if you have any other questions. :]
- Jason N
- firstnetgirlAspirant
Thank you that is very helpful.
Hi firstnetgirl,
I'm glad I could be of help to you. :]
- Jason N
