Chris0765
Aug 06, 2023Initiate
Nighthawk M1, Code 3 - Remove battery ans USB
Hello, if I use my Nighthawk M1 for a while, it suddenly switches off, the display becomes illegible (see pic.) and I get the error message "Code 3 - Remove battery to USB". It doesn't matter wheth...
Hazel2202
Oct 02, 2023Aspirant
Hi did you find a solution for this ? My router is showing the same fault
Chris0765
Jan 15, 2024Initiate
Hi,
sorry for the late reply.
No, I haven't solved the problem yet.
I also find it very disappointing for such a renowned company like Netgear that they leave their customers alone like that.
I can't find an address in Germany that I could contact for a repair.
Since the problem probably occurs more often, it would be right for Netgear to supply a replacement device for an additional charge.
But I will probably buy another device from another manufacturer - never Netgear again!
