Piet200
Nov 09, 2022Follower
Nighthawk M1 connect to LAN (ethernet cable)
I am looking for a setup to use the M1 mobile router as a backup of my internet on my lan.
Does anyone know if this is possible?
It does look like that I can hook it up to my wifi network and make it function as a backup in that way. but not when I connect it to my network using the lan port.
I tried the 'IP passthrough' setting, but that doesn't work at all.
Any suggestion is welcome.
- JohnPengNETGEAR Expert
Try WiFi OR ETHERNET offloading feature and see whether that is what you need.
Thanks
- mliTutor
If you want to do this seamlessly, you want to look into routers with failover or load-balancing functionality.
