Stephen1234
Dec 06, 2018Initiate
Nighthawk M1 data usage not displayed
After the most recent software upgrade, my M1 stopped displaying data usage. I took it into a Telstra shop, and they did a factory reset. Now it displays "Detecting service". It still connects to the...
- Apr 03, 2019
Fshow , thank you for the update and glad to know that it is now working.
Hi Blanco,
Went back to Telstra first with what i found reccommended elsewhere in the forum.
Kindly get in touch with Telstra and have them double check to ensure that it reached the billing server..
Back online now and sorted, thanks for following up with me.
Thanks
FShow
Blanca_O
Dec 19, 2018NETGEAR Employee Retired
Hi Stephen1234
Kindly get in touch with Telstra and have them double check to ensure that it reached the billing server. Please let me know what happen.
Blanca
Community Team
lukedeb
Jan 03, 2019Guide
Hi, like the above user, I too have lost Data Information since updating the firmware to NTG9X50C_12.06.02.00.
I have tried to roll back the firmware and upload the fix suggested with Firmware file
MR1100-1TLAUS_23113199_NTG9x50C_10.25.01.01_00_TELSTRA_03.22.secc but get a an "Invalid Update File. Error Code 16" every time.
I know this isnt a Telstra issue as this all worked fine until this latest Firmware upgrade. Can you please help me here as this is driving me nuts. What else can be done here to fix this?
Thanks
Luke
- VirgiliowJan 04, 2019Aspirant
The same problem for me here with my problem:
Firmware Version
NTG9X50C_12.04.02.00No response so far
- Blanca_OJan 17, 2019NETGEAR Employee Retired
Hi All,
We are currently looking into this. We will provide update the soonest.
Blanca
Community Team
- Albert1965Feb 17, 2019Aspirant
Any update on this issue.
I foolishily updated the firmware last week and should have checked these forums first. T
The previous firmware was working perfectly.
Current Firmware is NTG9X50C_12.06.02.00
Trying to roll back by installng older formware produces an error message.
- FshowMar 25, 2019Aspirant
Same problem also across 4 units, need help!!!
