Stephen1234
Dec 06, 2018Initiate
Nighthawk M1 data usage not displayed
After the most recent software upgrade, my M1 stopped displaying data usage. I took it into a Telstra shop, and they did a factory reset. Now it displays "Detecting service". It still connects to the...
- Apr 03, 2019
Fshow , thank you for the update and glad to know that it is now working.
Hi Blanco,
Went back to Telstra first with what i found reccommended elsewhere in the forum.
Kindly get in touch with Telstra and have them double check to ensure that it reached the billing server..
Back online now and sorted, thanks for following up with me.
Thanks
FShow
Fshow
Mar 24, 2019Aspirant
Same problem also across 4 units, need help!!!
Blanca_O
Apr 03, 2019NETGEAR Employee Retired
Hi Blanco,
Thanks
FShow
