Goldy_13
Dec 18, 2019Guide
NightHawk M1 does not show usage data and is attempting to detect service
Fireware has been updated and is running on the following NTG9X50C_12.06.08.00 no other updates available. The device has had no date usage for the past month and after doing a factory reset the devi...
kGf
Dec 18, 2019Aspirant
Hi. Had a nighthawk M1 for 8 months and it is showing same data and days left- has done for 17 days, even after recharge yesterday.. Can you tell me how to factory recharge, please ? Only suggestion I've had so far.
Blanca_O
Dec 19, 2019NETGEAR Employee Retired
There is a related thread with regard to this issue.
Blanca
Community Team
