CafeRacerShop
Sep 27, 2017Follower
Nighthawk M1 does not stay connected via WIFI
My New nighthawk M1 does not stay connected via WIFI to an Acer laptop running windows 10. I have already done a reset of the router. It will reconnect straight away but will drop out (WIFI) sometim...
- Nov 15, 2017
I think you are better off posting this on an Acer forum as you have confirmed yourself that the issue is not with the M1. As DarrenM mentioned it would be good to check if there is a WiFi driver update and if you are upto date with your Windows updates also. If your Acer is upto date then I would suggest contacting Acer.
Kind Regards,
ArodiD
DarrenM
Sep 28, 2017Sr. NETGEAR Moderator
Hello CafeRacershop
Have you checked for updated wireless drivers on that PC?
DarrenM
