Marcus1981
Oct 21, 2020Tutor
Nighthawk M1 Drops Connections Nightly with my Tplink Router! Help Please
I have my netgear plugged into my tplink Archer c50 router and everynight I have top reset nighthawk because I lose connection! I have wifi off on my nighthawk and use the tplink for wifi! Any suggestions on how to fix the issue?
Hi Marcus1981
Welcome to NETGEAR Community!
Kindly access MR1100 settings page and make sure that Ethernet Standby and WiFi Standby settings are set to disabled.
Access UI > Settings > Setup > Mobile Router Setup > Ethernet Standby (disabled or 2 minutes)
Access UI > Settings > Setup > Wireless > change WiFi Standby to Disabled.
Blanca
Community Team
- Blanca_ONETGEAR Employee Retired
Hi Marcus1981
Blanca
Community Team- Para61AspirantI have the same problem and have read something about the battery and the charger causing the router to overheat. I just made the changes you suggested, hence disabled the Ethernet Standby and WiFi Standby settings. We shall see.
