TimRy's avatar
TimRy
NightHawk M1 Firmware Update
MR1100-100NAS-04-01-74.00 hotspot, currently using firmware version NTG9X50C-12.06.08.00 build date 2019/10/16.
All is well, running great. But, I now have a new prompt about a new firmware available, is this correct? I am not seeing any information about software beyond the version already installed.
  • I downloaded the update and reran it from the hotspot gui, this fixed the 'update available' msg.
  • Hi
    I unable to update the latest firmware from Netgear.
    Method use to update https://kb.netgear.com/000061326/How-do-I-manually-update-firmware-on-my-MR1100-Nighthawk-M1-Mobile-Router
    Particulars of my unit ia as below.
    SKU MR1100-1EEEUS
    CURRENT FIRMWARE: MR1100-1EEEUS_23113575_NTG9x50C_12.06.03.00_00_EEUK_04.01.secc.spk
    Had tried many times with firmware MR1100-100EUS_23113509_NTG9x50C_12.06.11.00_00_Generic_10.03.secc.spk but unsuccessful.
    Error code as below
    Firmware update failed
    Invalid update file. This update is not intended for this product.
    According to support the above firmware is for my unit.
    Any help will ne very much appreciated.
