Midnightsun's avatar
Midnightsun
Follower
Mar 07, 2018
Nighthawk M1 in Canada
Can the Nighthawk M1 be used in Canada with a dedicated mobile sim from Bell mobility?
  • JasonN's avatar
    JasonN
    NETGEAR Employee Retired
    Hi Midnightsun,
    I just wanted ton confirm which model M1 is that? at&t or telstra?
    Please let me know :]
    - Jason N
    • JSchnee21's avatar
      JSchnee21
      Virtuoso
      I'm curious, too.  Do you live in Canada or just visiting?  The USA (and other) versions can be unlocked.  So if you end up needed to use a local SIM this is a possibility as well.  Though you will likely have to manually enter the APN.
      AT&T claims I should be able to roam with my MR1100 there and use my unlimited plus data plan "just like at home."  Similarly, I should be able to roam to all of Europe for $10/day.  Has anyone tried?
      When I roamed to Canada last year using my cheap ZTE 917 Tmo hotspot which has limited band support, connectivity was very hit or miss.  Typically once I got away from the US border it didn't work at all.  Hopefully the combination of the MR1100 and AT&T will work better.
      -Jonathan
  • JasonN's avatar
    JasonN
    Hi Midnightsun,
    I just wanted to check in with you and see if you're issue has been fixed.
    Please let me know. :]
    - Jason N
  • Hi,
    The AT&T nighthawk M1 would work with Bell in Canada, but you must make sure your Nighthawk M1 is SIM unlocked.  The Telstra may not be good to use with Bell.
