BusinessConnect
Apr 11, 2017Tutor
Nighthawk M1 Issues
Good Evening:
I've got a Nighthawk M1 (Telstra Supplied) in use as the primary internet connection for a client as their Fibre Connection has been delayed.
Generally speaking the device works well and is fairly solid however we have a couple of issues
1) The Router occassionally locks up and requires to be rebooted (Disconnect Power Lead, Remove Battery, Replace Battery and Plug Lead in again).
2) When rebooting the Router via the Web GUI it doesn't re-establish a connection, unless someone onsite does the reboot procedure above.
I've got the Router operating in a very "simple" mode, Wireless Disabled, DHCP Disabled, Purely acting as a Gateway only via LAN.
If Support has any ideas for me, or updated firmware I'd be appreciative.
- DarrenMSr. NETGEAR Moderator
Hello BusinessConnect
I have sent you a Private message.
DarrenM- Mark_at_LeSSSAspirant
Hi
I have a customer who can't receive ADSL or Fibre at the moment, and also wants to use the device in this manner. Can you send me whatever you sent to BusinessConnect please?
Mark:
I'd be very wary upgrading. I upgraded ours with the Beta Firmware and its pretty much "bricked" the Device. Connection remains active for around 60-120 seconds and then hangs with no Data Flow.
I've reverted to a Dovado Pro Router with a Sierra AC320U USB Stick Modem and that's been rock solid for 4 weeks+
- HaydenBInitiate
Hi,
I also have the problem of the Netgear Nighthawk M1 router locking up and requiring a reboot to resolve. This problem is occuring sporadically -- we can go for a few days without any problem, and then experience the problem every 5 to 15 minutes repeating for a number of times.
The Web and mobile app dashboards both show that the Firmware is up to date.
I'd appreciate any assistance to resolve this.
- ajlAspirant
I have a similar issue, the router can run for a day at the most, it then requires a power off, battery out reboot. The wireless service fails regularly, it can be five to ten minutes at a time. Then it may be an hour of wireless service, then down. Battery out, power out, reboot ahem.The device is essentially useless to us here.
Any clues appreciated.
- ajlAspirant
I am having the same issue with this device. It may run for a few hours fine, then the wireless service is inaccessible. It can be seen as a wireless access point but cannot be authenticated to, the error is 'Unable to connect to TPPW4G_1XY4.
The only fix is to unplug, remove battery, replace battery, replug, wait a minute or so, then it's back and working.
This can happen after five minutes or fifteen minutes or an hour, sporadically.
The firmward is up to date. I keep having this vision of it spinning around as it sails through the air heading towards the river.
- sweeteGuide
since upgrading to firmware NTG9X50C_10.16.04.04 i have had issues with the internet. when i first turn it on and it is using H (as opposed to 3G or 4G) it works fine (although not as good as it was prior to the firmware) but once it swaps to 4G it is shocking. the only way to get it to go back to H is to reset it.
i also have a 4G advanced II which works fine. to give you an idea my tests from speedtest.net are:
Advanced II (upload\download) and carried out 3 times
13.42/10.20
12.06/10.29
13.47/10.37
NightHawk M1 showing Telstra connection as H with full bars
17.42/2.12
19.88/2.38
16.91/2.40
NightHawk M1 showing Telstra connection as 4G II bars
6/.12
11.89/.29
6.49/.26
apart from the obvious speed differences, i work in IT and do most of my work connecting to clients from home and using RDP. so i need a reasonable upload spee and .29 is **bleep**!
I have been using my 4gAdvanced II for the last few months but just thought I would give the Nighthawk another go but hmmm still not working. What do i do? as you would all be well aware TALKING TO TELSTRA IS LIKE BANGING YOUR HEAD AGAINST A BRICK WALL!!!!!
Netgear please help!!!!
the update has turned many into worthless piles of poop, nobody will take responsibility for it.
time to get Tel$tra to step up and do something about it.
- ArodiDNETGEAR Expert
Hi BusinessConnect,
Are you using the device in IP Passthrough Mode or are you manually disabling WLAN and DHCP and setting a static IP on the device connected to LAN port?
Manually disabling WLAN & DHCP, Setting Static IP in the Device to act as the Gateway.
Device hasn't been used for 3-4 months since I posted, I have factory reset and used the device as a default Hotspot no custom settings and its operating as expected.. haven't tried using it as the Main Office Gateway Since.
