soletto's avatar
soletto
Nighthawk m1 low speed
Hallo,
i have similar problems speed at 2,4 ghz only max 72 mbit!!! Also with manually HT40 selecting.
I tried on 2 computers. This should be fixed because the router is very expensive.
The router is always on so i dont want to always plug of the cable. So how should it be used. It should be no problem to always let in the cable as the internal loading management should manage it.
Best regards Stefan
1 Reply
  • ok problem solved i use the router while putting out the akku
