Bansisingh
Nov 05, 2018Tutor
Nighthawk M1 Mobile Hotspot as Home WiFi
I have the M1 Hotspot and am using it as a WiFi for my home. Works pretty well, good speeds, all systems hooked up fine. The only issue I have is that the distance of the WiFi/Hotspot is not very far...
Bansisingh
Nov 06, 2018Tutor
Bansisingh wrote:
I have the M1 Hotspot and am using it as a WiFi for my home. Works pretty well, good speeds, all systems hooked up fine. The only issue I have is that the distance of the WiFi/Hotspot is not very far. Is there any way to boost the internal radius inside my house? I would prefer to mount the Hotspot nearest to the wall/window that has LOS to the tower, but I find that on the other end of the house I don't connect to the wifi. Just curious what my options are. Thanks!
Thank you so much i got my answer
_____________________________________________________________
https://appsync.biz/speed-test/ https://appsync.biz/scrabble-word-finder/ https://appsync.biz/solitaire/
