Bansisingh
Nov 05, 2018Tutor
Nighthawk M1 Mobile Hotspot as Home WiFi
I have the M1 Hotspot and am using it as a WiFi for my home. Works pretty well, good speeds, all systems hooked up fine. The only issue I have is that the distance of the WiFi/Hotspot is not very far...
Tusc
Nov 05, 2018Aspirant
From what I've read the wifi range on the M1 is not as strong as a typical home wif router. Why not repurpose an old Wifi router as your primary access point? You can hook up the M1 to the WAN port of your old router.
I just ordered an M1 and plan to use it as my secondary home internet access. I have an RT2600AC that has dual WAN support and plan to connect it to the second WAN port and leverage polcity routing.
hotwater9
Apr 07, 2019Aspirant
Did you get this setup working? I have a RT2600ac but am unable to get it to work with my LB2120 modem as a wireless backup.
